should this car run?
Discussion in 'HYBRID -> ED-EF / DA' started by driveordie, Dec 26, 2005.
  1. driveordie
    driveordie Junior Member
    Gloucester VA
    should this car be able to run? here is what i've found so far....
    -b18a1 motor from a 93 integra ls (obd1)
    -crx si distributor (obd0)
    -pm6 crx si ecu (obdo)
    -not sure the injectors, i think they are probly from the crx si as well because thay are 0bdo and use the injector box.
    -no charcoal canaster (emissions control)
    -no fuel pressure regulator cut-off solenoid
    -no purge cut-off solenoid
    -idle air control valve not connected
    i picked up the car for $300 body is in great condition. but motor cranks but won't start...i thought half of these things were not compatable with the b18a1. what should i change to get it to run. please help
