Si Cam In A Dx?
Has nothing to do with the ECU and you do not "need" an adjustable cam gear. It drops right in. Depending on what year it is from the cam may be off from stock. Therefore your powerband will be higher or lower in the RPM range. Look at Mista Bone's page http://home.cinci.rr.com/mistab0ne/dyno.html for more details.
