I own a 1990 CRX DX converted to mpfi. Someone broke into the driver side and it got wet before I could put in a new window. The key switch and all electrical work but it won't turn over unless I jump the starter out. It runs fine and throws no codes. The clutch switch is good and I also replaced the starter relay and all of the fuses are good. The dash lights come on like they should but don't cut out like they should as you try to crank it- they only flicker. Could it be the main reply or something else? Could some pm me asap w/ some suggestions because this is my daily driver and my fiance needs her car also to get to work. thx
