Si Dash into HF wiring.
Discussion in 'Civic and CRX - EF' started by the.original.kermit, Jun 26, 2008.
  1. the.original.kermit
    the.original.kermit I know everything
    Hamilton, MI
    I'm swapping in a 1989 Si dash into my 1989 HF, and one of the connectors is different. I took some pictures of it. It looks almost the same, but is a little wider.
    Here's some pics
    Si Dash Plug
    HF Dash Plug (Notice, not as wide)
    It would be great if someone could get me the wiring diagram for this, or tell me what all of the wires are. I'm going to go work on seeing if I can trace them or something.
    Thanks,
    Tony
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    j/w but why not just swap the dash its self with out the wires use the wires that you already have
  3. the.original.kermit
    Hamilton, MI
    I could look into that. I'm guessing that these wires go into the clock or something that I may want to keep.
  4. the.original.kermit
    Hamilton, MI
    Ok, not the clock. Possibly sunroof controls?
    If someone could scan a page out of a manual with the wiring diagrams, that would be great. Especially since I'm color blind. Makes it a little hard to trace wires by color, lol.
  5. 89civicsnatch
    89civicsnatch New Member
    Cheyenne, WY
    what colors cant you see?
  6. the.original.kermit
    Hamilton, MI
    I'm red/green, but I have trouble with blue/purple too.
  7. the.original.kermit
    Hamilton, MI
    I'm going to use the HF dash wires inside of the Si dash like suggested. I really can't find that much of a difference between the two, besides the lights that the Si have for the cigarette lighter and the little tray by it. Interesting is the fact that the Si dash has one less radio wire than the HF does... Not sure why and what it's for.
    Still trying to find some sort of wiring diagram... maybe a torrent or something?
  8. the.original.kermit
    Hamilton, MI
    Ok, the HF wiring harness was hacked up pretty good from the previous owner. I'm trying to wire up the radio right now by splicing in the radio connector from the Si. Here's my question:
    I have 1 red/black wire coming out of the Si radio harness, it splits into 4 red/black a few inches down. The HF harness has 3 red/black that go to the radio. I'm assuming that these are the speaker grounds so it's safe to combine them all, but why does the HF harness only have 3 if there are 4 speakers?
    The only thing that I can think of is that the two rear speakers might have a common ground...
  9. 89civicsnatch
    Cheyenne, WY
    Speaking of wich I need the 90-91 cluster harness clips
  10. the.original.kermit
    Hamilton, MI
    1 person likes this.
