Si Ecu Or Gsr Ecu
Discussion in 'ECU's, Electronics, and Tuning' started by seeingred, Mar 4, 2003.
  1. seeingred
    seeingred Junior Member
    I put a 2000 b16a2 in my 98 civic ex, I used the 00 engine harness and the p2t ecu(obd2b b16a2 ecu) and i have a mess of wires in my dash to try to make it work and i keep getting codes! Has anyone done the swap, used the stock engine harness that came with the old motor(d16y8) and used a 96-98 GSR ecu? and if so does it run normal? Or is there an easier way to do this wiring crap?
    Any coments would help---Thanks
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    the gsr will run your engine, although the fuel curves are not identical .
    but you will not throw a code for not having iab's
  3. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    It would have been easier if you used your stock EX harness, and added a couple of wires to it.
    Then you can use a 96-97 delSol B16A OBD2 ecu, and it would be plug and play.
