Si Head Question ?
Discussion in 'General Tech and Maintenance' started by plonger1234, Mar 9, 2003.
  1. plonger1234
    plonger1234 Junior Member
    Is it normal to have brown valve ? Because the head was stored in the three last month ?
    The gasket was brand new but the block blow up because of an ghetto rebuilt . I hope the head is still good
    http://home.1asphost.com/plonger/si-head.jpg
  2. CRX-YEM
    Wallingford, CT
    I hope you plan on rebuilding htat head before you plan on using it.
    the brown on the valves is surface rust it happens. before the head was stored
    you should of sprayed it down with WD-40, it would of helped a lot.
    you might be able to remove the surface rust and use reuse the valves depends
    on how bad they are. You might have to purchase some new valves
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Looks like they could be useable,pull em out and hit 'em with steel wool and WD 40,if they start to look right after just a little bit of rubbing,they can be saved.
  4. plonger1234
  5. plonger1234
  6. plonger1234
