Si Head
Discussion in 'Engine Building' started by TeamCivic, Apr 3, 2003.
  1. TeamCivic
    TeamCivic Junior Member
    hey guys,
    my buddie has a 92 civic vx hatch and apparently it has the economical vtec, anyways, he wants to swap a 92 civic si head and ecu on it for the more powerful vtec :)
    My question is: is it worth it? i mean is it worth swapping the head and ecu, will it make a difference. From what i'v been told it could gain you upto 20hp. is it really worth the hassle. I dont' know how hard a job is it.
    anyways, your 2 cents would be appreciated..
    thanks,
    Blair :D
  2. TeamCivic
    Also know as the "mini me swap"
    anyone.. :D
    Blair..
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    it's easy. you can get 20 hp. it's worth it if you dont' want to do a b series swap
  4. smurf bnms
    smurf bnms Junior Member
    Tampa, FL
    The gearing on that engine is extremely wide. Apparently the economical part infected the engine and the transmission. Make sure you get a different tranny ( EX or SI, if they will bolt up?) to make that extra hp worth it.
  5. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    If you can score one cheap, go for it. I'd just save up for a B. If he does deside to go for it, the vx tranny should be fine.
  6. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    if you need an Si tranny I got one for sale. it includes the fully intact tranny, shift linkages, and axles. only $200. if you live in SoCal you can come and pick it up.
  7. TeamCivic
    thanks guys, but i think i am going with a b series engine.. i cant afford too much right now, but i think i found a b18b that i can grab for cheap.. i was really looking for a b16a2, but outa my price range..
    blair..
