Si-rII
Discussion in 'General Tech and Maintenance' started by klei2fast, Apr 5, 2004.
  1. klei2fast
    klei2fast Senior Member
    Twin Cities
    Is this the exact motor that is in the 99-00 si's. I am confused. Or is it something else? If it is something else, what is the other code for it. I know that it is a b16a2.
  2. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    dude, check the reference section- the Sir-II is NOT the same motor found in the 1999-2000 civic si-
    http://www.hondaswap.com/forums/index.php?showtopic=29825
    the Sir II came in the JDM 92-95 Civic Sir II and had 170 hp while the B16a2 is the motor found in the 99-00 civic si and it made 160 hp
  3. brian11to1
    brian11to1 Senior Member
    Most people dont search much, I used to be like this, then I found my testicals. So search.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Si's 99-00, SiR/SiRII's everywhere except for Canada have B16A's or a variant of B16A, such as the B16A2, B16A4, and on, in them.
  5. klei2fast
    Twin Cities
    I just won a bet based on this. Thanks guys. I knew they weren't the same motor but I needed proof.
  6. xj0hnx
    C.C.TX.
    You should have lost the bet because they are all B16As. Just in Japan after 92 they ran a different piston.
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    they are rated at 10more hp to the flywheel, the SiR2 motor
    can't confirm, but I believe they also run a little more agressive cam profile on the SiR2 - like I said you might want to check that out
    but yes they run 10.4:1 CR
