Sigh* why I hate VT
CREG!!!!!!!!!!!!!!!!!
how much for just the headliner?
reminds me of a brothel :thumbsup:
D17a?
Must be bored/stroked.
??? or maybe he has the stock engine for a 02 civic
he didnt specify the model so ill just cover them all
D17A1
  • Found in:
    • 2001-2005 Honda Civic DX/LX/VP
      • Displacement : 1,668 cc (101.8 cu in)
      • Bore and Stroke : 75 mm × 94.4 mm (3.0 in × 3.7 in)
      • Compression : 9.5:1
      • Power : 115 hp (85.8 kW, 117 ps) @ 6100 rpm
      • Torque : 110 ft·lbf (15.2 kg/m, 149 Nm) @ 4500 rpm
      • Valvetrain : SOHC (4 valves per cylinder)
      • Fuel Control : OBD-2 MPFI cut: 180kmh
D17A2
  • VTEC-E
  • Found in:
    • 2001-2005 Honda Civic EX (US only)
    • 2001-2005 Honda Civic LX (Europe)
    • 2001-2005 Honda Civic Si (Canada only)
    • 2001-2005 Acura 1.7 EL (Canada only)
      • Bore and Stroke : 74.98 mm × 94.4 mm (2.952 in × 3.717 in)
      • Rod Length : 137 mm
      • Rod/Stroke : 1.48
      • Compression : 9.9:1
      • Power : 127 hp (94.7 kW, 129 ps) @ 6300 rpm
      • Torque : 114 ft·lbf (15.8 kg/m, 155 Nm) @ 4800 rpm
      • RPM redline: 6800 rpm
      • Rev-limiter : 7200 rpm
      • Valvetrain : SOHC VTEC (4 valves per cylinder)
      • VTEC Switchover : 3200 rpm
D17A6
  • VTEC-E
  • Found in:
    • 2001-2005 Honda Civic HX
      • Power : 125 hp (93.2 kW, 127 ps) @ 5800 rpm &
      • Torque : 111 ft·lbf (15.3 kg/m, 150 Nm) @ 3800 rpm
      • Valvetrain : SOHC VTEC-Ec (4 valves per cylinder)
      • VTEC Switchover : 4400rpm
have a nice day
Thats what happens when you live in the boonies without anything to do.
