Signal Light / Temp Problem
starboy869
Hi,
Ok.. I'm at a lost.
I'm having a problem with my signal light & temp gauge.
Most of the time ONLY when I'm moving (even 1 kph) & when I have my signal light on in either direction my temp gauge will move up & down with the flash.
This doesn't happen when I'm at a full stop.
I've added a missing ground wire from the valve cover to the frame. This fixed the dash signal from going dim. What gage of wire should this wire be?
Also I changed out my neg. battery cable with no luck regarding the problem.
Any ideas? I'm still banking on a bad ground.
as am i.
check your fuse boxes for any hanging wires, or croseed wires.
also, check light bulbs. some bulbs have dual filiments... and if one brakes, and crosses onto the other, its been knon to cause wacked out results.
