single and need advice
Discussion in 'Members' Lounge' started by vicky, Jul 23, 2007.
  1. vicky
    vicky New Member
    Los Lunas NM.
    i put 20 bucks of gas in my car and the gage still read empty then with one trip to alb it ran out of gas. ( i had just went to school and back.)what might be wrong with it? normally i would ask "that guy" but were not together havent seen him in a couple of days and really need advice on what to do i need to fix it asap.
  2. eg6sir
    heres some advise.. drive to CA..
  3. vicky
    vicky New Member
    Los Lunas NM.
    well i would need my car fixed to do that. :p
  4. klyph
    klyph Dismember VIP
    North Pole, AK
    Does it smell like there is gasoline leaking anywhere?
  5. vicky
    vicky New Member
    Los Lunas NM.
    no
  6. klyph
    klyph Dismember VIP
    North Pole, AK
    Black smoke out the exhaust?
  7. vicky
    vicky New Member
    Los Lunas NM.
    ya kinda
  8. eg6sir
    sounds like its running rich and spitting more fuel into the motor than it can handle.. is the car running kinda crappy
  9. Celerity
    Celerity Well-Known Member
    Nothing to do with being single, thanks for the eye-catching (or popping) title.
    Your gauge doesn't work. Fix it.
  10. get_nick
    Washington State
    next time you fill up, set your odometer (trip gauge) to "0" and see how many miles exactly you are getting per tank.
    it could be anything from a clogged air filter to bad fuel filter or a bad spark plug.
  11. nootrac22
    exeter pa
    start a gas fund. post up some nice pics and all the guys here will chip in to help you with the gas. :p
  12. reckedracing
    reckedracing TTIWWOP VIP
    NY
    20 bucks bought you about 6 gallons
    how far away(miles) is school?
  13. Jeef
    Jeef NO MA'AM Moderator VIP
    :withstupid:
    That would probably give you half a tank, with a Honda gas gage it would probably read 1/4 then up to 3/4 then to empty as you are driving. I hate Honda gas gages.
    Rumor has it that if you show more booty pics your mpg will go up.:ph34r::moon:
  14. Capt. Orygun
    Capt. Orygun Win the Day
    Oregon
    I just had this problem (fuel economy), just start looking, start with the easy stuff and work towards the tougher stuff
    Questions to ask yourself
    have you changed your oil in the last 3,000 miles
    if yes then
    Have you changed your air filter in the last 30,000 miles
    what about your spark plugs
    howabout your wires
    how about your fuel filter
    if yes to all that
    is your check engine light on? Could be your O2 senor or similar
    is it backfiring? Could be running Rich
    there is a 1000 things that could be wrong. Troubleshooting isn't about finding out what it is, it's more about finding out what it isn't
  15. vicky
    vicky New Member
    Los Lunas NM.
    ya actually
  16. vicky
    vicky New Member
    Los Lunas NM.
    actually it does have to do with being single i was with thatguy4life whos on here but we broke up and i dont really have anyone else to check my car. and i didnt want someone who knew him to tell me why dont you just ask your bf. so it was extra info.
  17. vicky
    vicky New Member
    Los Lunas NM.
    thanks ill try that umm around 30 miles
    still kinda new at this.
    lol your funny
    thanks for your help.
  18. Capt. Orygun
    Oregon
    running rich could be a post cat O2 sensor
    symptoms are
    rough idle
    backfiring and sputtering
    terrible fuel economy
    basically the rear O2 sensor tells the engine how much fuel it needs (on a real basic level). Without the O2 sensor the ECU takes a "better safe then sorry" approach and starts dumping fuel into the engine
  19. Black Widow g2
    Black Widow g2 *princess*
    California
    clogged the fuel filter when it ran out of gas? likely. :)
  20. dveit
    dveit Well-Known Member VIP
    DMV
    Get a boyfriend, quickly.
