Sir speed sensor
wisemansoji
I need to know where the speed sensor wire goes in the ecu, my speed gauge doesn't registor a speed while i drive, I know the wire goes in the pin c18. 2000 sir engine in 94 HB. but i can't locate where the c18 pin is on the ecu how do I find that pin. and does the vehicle speed sensor have one wire or 3.
I think you are confused.... the VSS goes to the following pin out...
obd2a-C18
obd2b-C23
obd1- B10
so what ecu are you using?
you better get that fixed before you get a speeding ticket..........haha
so, you re-wired your entire car to use the 2b ecu? why and how?
the 2b ecu has an imobilizer-- so you changed ignitions too? got the keys? and the ecu?
why you didn't just plug in a chipped p28 or a p30 is beyond me....
