SIR2 into 96 Civic DX Wiring
Discussion in 'HYBRID -> EG-EK / DC' started by honda_power69, Oct 7, 2002.
  1. honda_power69
    honda_power69 Member
    Okay, The mounts, the tranny, and as far as bolting everything in and running all the lines and hoses I can do fine on my own. My question is, does anyone have the Wiring Diagrams I need for this? I'm using a P30 ECU, and dont have my wiring harness yet (the ECU side, I have the side connected to the motor). Please any info, really just the diagrams, would help. Thanks.
  2. B16
    B16 Super Moderator VIP
    yay area, CA
  3. pissedoffsol
    why in gods name are you using a p30?
    you have an obd 2 chassis and an obd2 motor...
    WHY use an obd 1 ecu? it makes no sense at all.
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    an sir2 is obd1... the p30 is obd1... his chassis is obd2, so www.hondata.com conversion harness.. your money
  5. honda_power69
    Okay, I have most all of the wiring done now...just finished today, but there are a few things that I'm unsure of...On the driver-side of the engine bay, (with the SIR2 wiring), there are 3 harness connectors. One has all yellow/black wires that is plugged off, I'm guessing its a common ground. Then there is a 14 wire connector and a 2 wire connector. If anyone has the pinout to the 14 wire connector (its number is C126) then it would be greatly apprectiated. Also, a pinout of the singe 10-wire connector that the 96-98 civics use in place of these 3 connectors in the same spot would be helpful as well.
