and it will be a bitch to wire.
you'll end up buying all sir2 electronics or totally re-wriign for things like distributors, alternators, injectors, and so forth...
and sir1 cams are less lift/duration than sir2's.
if you're planning to buy an sir1 over the sir2 in hopes of it being cheaper- in the end, you will spend more trying to get the sir1 to work, have a mirgraine from wiring, and still be slower than if you jsut bought the damn sir2 in the first place.
