skunk 2 92-95 civic camber kit on crx?
crxz6
will the new 92-95 adjustable control arm from skunk2 fit a 90 rex si ? i know the 96-up are different. but the stock control arms on the 90 si and the 92-95 civic are pretty much the same.
The 92-95 has larger (well they're different anyway) control arm mounts than the 88-91 CRX. You might be able to use them, but you'd probably have to use spacers or washers to keep it tight, and you don't really want to shim a high stress rotating joint.
