skunk 2 intake manifold
Discussion in 'Integra' started by skee10, May 22, 2007.
  1. skee10
    skee10 skee10
    Front Royal
    i have a skunk 2 intake manifold for my 99 ls....and my motor only has 85k on it...and is like brand new...but any way...if i put it on...how much horse power should i get ....and is there anything else i could upgrade to get the full potential out of it ?
  2. hazzardboy95
    hazzardboy95 Hon-daaaa
    Pasadena, Md
    Larger throttle body, bigger injectors, high flow fuel rail, fuel pressure regulator. I would also put a stronger ignition coil in to make sure I burn the full mixture. Thats what I did. You looking at about 20-30 more horses at the motor.
  3. skee10
    skee10 skee10
    Front Royal
    well for now just putting the manifold on how much hp gain am i looking at.....all i have done so far is skunk2 cat back exhaust and aem shor ram intake....????
  4. eg6sir
    :bo: :bo: are you serious?!?!?larger throttle body, yes.. injectors, no.. fuel rail, no.. fpr, not necessary... ignition coil, no.. Honda has one of the best factory ignition systems.. cams will give you the most power with a tune
  5. skee10
    skee10 skee10
    Front Royal
    so a larger throttle body....any cirtin size?....and like i said..im just starting this build...all i have is a aem intake....skunk2 catback exhaust and the intake manifold....so if u recomend a cirtin size...plz let me know...thanks.....
  6. eg6sir
    i'd invest in a set of cams first..
  7. skee10
    skee10 skee10
    Front Royal
    ok...thanks for the info.....any spacific type u would recomend....????
  8. 99sidude
    Ohio
    with all that money you will be spending you could get a vtec head and see the same gains, as well as have much more N/A potential.
  9. eg6sir
    but with all that money you spend on the vtec head and other components necessary to do the head swap you could have a decent turbo setup and blow away the ls/vtec
  10. 99sidude
    Ohio
    could you really get a "relaible" turbo setup for the cost of a head swap?
  11. skee10
    skee10 skee10
    Front Royal
    yea i was alos thinkin about ls/v....just a built and boosted ls.....any suggestions
  12. TAGURIT
    TAGURIT New Member
    bigger throttle body and cams..........you've already started in helping the motor breathe better with the exhaust and intake. you can save the ignition for later. or you get a complete head package from gude performance about $1400.00 and it guarantees you 45-50 hp to the wheels. people may wonder why i keep pushing their products, its because i have it and its proven.
  13. hondaricerman
    hondaricerman Banned
    skunk 2 im are sick i would plan on around 35 whp gain
  14. 99sidude
    Ohio
  15. TAGURIT
    TAGURIT New Member
    those were my sentiments. if you got 35whp from an intake manifold, you just out did twm itb's
  16. skee10
    skee10 skee10
    Front Royal
    lol...yea i was like 35 whp....no fucking way....lol..but any way...does anyone that knows what there talkin about have any idea how much gain i would get...or how it will make the car perform or anything like that ?
  17. 99sidude
    Ohio
    Idk maybe like 8-10whp... It doesn't seem like alot, but will definately be noticable on the butt dyno. Get a set of good cams along with and you will see some great gains.
  18. eg6sir
    you wont gain any where near 8-10 whp from an intake manifold.. with cams and throttle body you can gain that much from the S2 IM.. remember, mods work together.. and to get the full potential out of the part.. you'd need to upgrade other things.. i'm guessing 2-4 whp just from the manifold
  19. skee10
    skee10 skee10
    Front Royal
    i was thinking about either aem or skunk 2 cam gears....and a bigger throttle body also....and possibly a camsaft...but im not sure which ones would be better for my car.....any ideas?
  20. eg6sir
