Skunk2 Cams, Itr Springs...
Discussion in 'Engine Building' started by mattcalica, May 28, 2003.
  1. mattcalica
    mattcalica Senior Member
    k, i want to use skunk2 stage 2 cams, with some itr valve springs and retainers because my friend will give them to me cheap...will this setup work? also, i wanted to use a spoon headgasket to up the cr...will i run into any piston-valve contact while running these cams?
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    clay the engine
  3. E_SolSi
    you should use a better spring
    the stock ITRs are not gunna hold up to the skunk stage 2s
  4. pissedoffsol
    :withstupid:
    skunk stage1's are bigger than itr's.
    stage 2's are even bigger...
    you'd want to use skunk2 valve train, or better yet, portflow :)
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    for the headgasket just buy a oem unit and take the middle layer out, same shit but half the price. And check out the sticky cam guid I have on the top.
    Milan
  6. JDMilan
    Boca Raton, FL
    Skunk2 Stage 2
    Int-266 dur. / 12.3mm lift
    Exh-262 dur. / 11.8mm lift
    Valve Springs to be used: Skunk2 preferred but Port Flow will work as well. These cams are wild enough that you should not be using the low 8200rpms rev limit.
    Description: The new top dog of the cam world. This will become the most common aftermarket (non OEM) cam in the US when they start getting distributed more. These have a very similar power band as the JUN Type 3, with less cost and better reliability (I said the “r” word). Not huge midrange but very good gains from 7000rpms all the way to 9000rpms(peak is usually around 8000-8200rpms). These cams have stock idle characteristics, thus making them the ultimate street/strip cam. I recommend using Skunk2 cam gears with these cams.
  7. B16
    B16 Super Moderator VIP
    yay area, CA
    i was running itr springs and retainers on skunk2 stage 1's and that was pushing it. spend the extra money and build it with the proper pieces, you run the risk of floating a valve if you dont, which = bad.
  8. mattcalica
    okay, where can i get these portflow springs from? any websites that carry them?
  9. Iquark
    Iquark Senior Member
    Mount Vernon, WA
    You can get them at portflow. They have the prices listed, so you can compare to anywhere else, but I would always like to get a product at the manufacture's place than somewhere else.
