Skunk2 intake manifold
Discussion in 'Engine Building' started by knowledge, Nov 13, 2003.
  1. knowledge
    knowledge Senior Member
    Beale AFB, CA
    I got a 2000 ITR and recently put on a skunk2 IM but the bung on the back of the manifold for the evap. control valve wasn't there. But behind the #1 runner there was a small bung that on the ITR don't go to anything. So what I am asking is on a B16 that little bung on the back of the IM behind the #1 runner, where does that go to? I capped off that little bung and also capped of the evap. control valve vacume hose. It ran fine for a week then last night it threw a CEL. I am thinking of getting the evap.control valve hose to connect to that little bung. Any suggestions?
  2. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    call Skunk2 and ask them what the deal is.
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    what did you do with your ITR mani?
  4. knowledge
    Beale AFB, CA
    I called Skunk2 and they said I have to tap into the manifold behind the #3 runner and put a bung into it. Sounds like a bitch to me. I am thinking of routing it to that smaller bung behind the #1 runner.
    I still got the mani bro! ;)
  5. B16
    yay area, CA
    i would just T off an existing hose then, you can get the plastic t's for damn cheap at pep boys :)
  6. knowledge
    Beale AFB, CA
    they closed pep boys here. I will need to get a fitting that reduces the sise of the hose from the evap control valve hose down to that little bung. Hope I can find a fitting somewhere...
  7. knowledge
    Beale AFB, CA
    Just incase for future references I got a reducer fitting and a smaler vacume hose and hooked it up to that extra bung behind the #1 runner. No CEL yet!
  8. liquid00meth
    Laconia, NH
    sounds like a good fix to me. Nothing should be different between the runners...
    :thumbsup:
  9. knowledge
    Beale AFB, CA
    Yeah thats what I was thinking except for the size difference in the bungs from the larger one on the Type-R mani to the real small one on the Skunk2 mani. Hopefully it is a permanent fix.
