It flows better than stock and will make more power than stock.
Now, if you want to know some of the disadvantages, there is one HUGE one....the Skunk2 is the EXACT same as a Blox manifold, and the Blox is a LOT cheaper.
What kind of modifications are done to your engine?
If you don't have a need for the increased airflow the manifold will not do much at all for you, and may even make less power if you have a stock engine.
Ooh, H-series...You're probably going to have to stick with Skunk2 for anything aftermarket, unless you want to go with a big clunky sheetmetal manifold (which will actually lose power unless you're running a lot of boost).
