Skunk2 Throttle Body and Intake Manifold Problems
Yurik
I have a 1991 honda CRX with a b16a1 OBD0 swap, i bought this intake manifold and throttle body after seeing that it was SUPPOSED to fit my year engine, and now i have problems
1) this throttle body requires a bottom mounted map sensor, where as my map sensor is on the fire wall
2) my fuel rail has the FPR in the middle of the fuel rail, and does not clear my intake air temperature sensor, and requires the mounting of the FPR at the end of the fuel rail
3) the intake does not clear the alternator bracket
4) the throttle cable does not clear the intake air temperature sender
obviously 3 and 4 are easy fixes, just a little griding down, not a big deal, but what in the world should i do for 1 and 2? i was thinking i could take a fuel rail off a newer GSR b18 and swap it over, or buy an AEM or something and hope it has the FPR mounted at the end of it
now, i still have NO IDEA what in the world i should do about the map sensor and need advise on the fuel rail, please help!!
