  1. hondacivicdx92
    hondacivicdx92 Hamby
    Indiana
    Ok, so I am going to be taking my car to the strip once I get my turbo back from being rebuild and was thinking of getting some slicks for run when I start going to the track more. I didn't know what a good size slick would be to run without the rubbing. Another question I had is where can I find slicks to fit on 14's and also where can i find some good 15 drag wheels and slicks?
  2. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    mickey thompson makes 14" slicks , as for sizing as close to stock as possible . your in indiana try tire rack , they don't keep them in stock but they can order them , Mickey Thompson Performance Tires & Wheels be aware some tracks require extended lugs with slick , also if your axels are not upgraded slicks are a good way to break them
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    best size is 14's..you can go with 15's but it woll probably bog unless your making real good power..
    just fit them to your stockies
    1 person likes this.
  4. newb
    newb phresh VIP
    Backwoods Northwest
    Check all your stuff and make sure your NHRA legal for slicks. It would suck to spend all that money on some nice tires, then find out you cant run em cuz you havent met all the safety requirements.
  5. TurboMirage
    im having a great run with hankook ventus slicks, but then again i autocross.
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    hankook FTW!!! i ran hankook street tires on my circletrack car,,,real nice grip!!
  7. efhondakid
    Akron-Canton, Ohio
    I got a set of them too, havent put thempon yet, theyre shaved to 3/32nds I cant wait to see how they hook up.
  8. hondacivicdx92
    Indiana
    thanks for all the info guys.
    one more question though. If I don't go with slick, what it a good sticky tire that I can get for the stock steelies?
  9. Bkkfarang
    Hoosier DOT Drag Radials P225/50R15 might have fitment issues ,Nitto NT555R Drag/street Tire (205/55R14 85V),Mickey Thompson ET Street Radial P205/50R15 ,Mickey Thompson ET Street Radial P225/50R15 might have fitment issues, Nitto 555r 205/55R14 , again keep as close to stock dia. as possible . all will give better traction the normal street tires , other options are roadrace and auto cross tires , but they are not the best thing to drag race on .
  10. INJEN78
    INJEN78 HS LEGEND
    OHIO
    drag radials...any kind really, but check tire compounds and remember,,the harder the tire,the less the grip but the longer lasting
    and the softer the tire,the more grip,and short lasting
  11. newb
    newb phresh VIP
    Backwoods Northwest
    ^ :werd: Climate is a factor too. If your in a cold area its gunna be difficult to warm up a hard tire, and keep it at temp.
  12. TurboMirage
    advan A048
  13. tunerguy22
    tunerguy22 Banned
    These guys have all given great advice....but remember one thing, the harder the launch and the more traction ya get, the more things are going to break.
  14. 97hatch
    97hatch ?
    Anderson IN
    where in indiana are you located i have a set of 22x8x15s that i need to get rid of there m/t
    i also have a set of 24x8.5x13s and 25.5x8.5x13s
  15. hondacivicdx92
    Indiana
    I am about an hour or so west of indy on I36
  16. 97hatch
    97hatch ?
    Anderson IN
    would you be intested in the 22x8x15s they are on wheels for 150 i might be able to meet you some where im up in anderson about 30 min north of indy on 69
  17. gettocrx
    gettocrx Member
    Honolulu, HI
    Falken azenis 615 are good street/strip tires also!
