rudeludenotmeanthough
I MUST go for smog check ina bout a half hour. I plan on using denatured alcohol.
My only concern is that i have about 2 gallons of gas in the tank at this time.. and the mixture is suppose to be denatured 2: gasoline 1... will this 2:2 ratio make me not pass smog.
Or should i try to get as much of this gallon out as i can?
Calesta where are you??!?1
