Smoke coming out of filler hole. D16z6
Discussion in 'Engine Building' started by hmtcrxsir, Jul 30, 2005.
  1. hmtcrxsir
    hmtcrxsir Member
    well when i spun my bearings on my D16z6. I opened the filler cap. And there was like oil vapor/steam coming out of it. You think i might have to replace the rings on the pistons?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Not necessarily. At operating tempature, there will usually be some steam/vapor coming out from your oil filler cap hole when you pull the cap. Perform a compression test or leakdown test to see if you need new rings.
  3. brian11to1
    brian11to1 Senior Member
    i didnt think you should open the oil filler when its running...
