?Smoking?
Discussion in 'Civic and del Sol - EG and EK' started by 94tuner, May 9, 2011.
  1. 94tuner
    94tuner New Member
    For some reason my 92 civic (mini me) is producing a grayish white smoke (from what i can tell from inside the car) It really only does it from about 3k rpms to redline. Not burning access coolant, and buring a little bit of oil. And im not feeling a power loss. Any ideas what this could be?
  2. eg6sir
    White smoke-coolant
    Blue/grey-oil
    black-rich fuel
    How many miles on the motor?
  3. porkfried83
    porkfried83 New Member
    ME
    Could be blown head gasket or rings
  4. 94tuner
    94tuner New Member
    The Odometer say 120k but since it is a hybrid motor im not sure about the mileage on the head. As far as a blown head gasket or piston rings is concerned is there anyway to check those without physically taking the head off? Compression test maybe?
  5. Fernpatch
    Fernpatch Member
    Bellingham,WA
    A compression test and a leak down test could tell you alot about the health of your motor. Also just pulling the spark plugs and looking at them can tell you alot about what is nurning inside each cylinder. Look for discoloration, ash, or deposits on the insulator and electrode of the plug.
    1 person likes this.
  6. 94tuner
    94tuner New Member
    Checked the plugs couldnt see anything wrong with them? Is there a chance than it could be caused by bad valve seals or something in the head?
  7. eg6sir
    yes.. that or bad rings
  8. raabdunn
    raabdunn New Member
    hybrid motor? lsvtec or b20vtec. did you put on a system of venting crankcase pressure?
  9. raabdunn
    raabdunn New Member
    oh wait. nvm i didnt see the mini me part haha sorry about that
  10. sohcVsol
    sohcVsol New Member
    i had the same problem wit mine, it had high miles nd head gasked nd rings were shot!!
