So California: FS Built 1995 Honda Dx
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by Johnnylawless, Jul 9, 2008.
  1. Johnnylawless
    Johnnylawless Senior Member
    Fully Built 1995 Honda DX:
    MOTOR: (1600 miles on rebuild)
    B16a Sleeved with GE HD Sleeves, to 85MM
    Wiseco 10.5:1 85MM Comp. forged pistons
    Scat Forged B16a Rods with ARP studs
    Factory Honda crank and rod bearings
    ARP Crank Studs
    750CC RC Fuel Injectors
    Type R piston oil squirters
    Type R oil pump
    Type R Water Pump
    Type R oil cooler
    Type R oil pan (extra ½ quart oil capacity)
    Type R harmonic dampener pully
    Type R Alternator
    Type R fuel rail
    Type R ThrottleBody
    Type R Head
    Type R Cams
    Type R Distributor
    B&M CommandFlo Fuel Regulator
    AEM TRU-Time Cam Gears
    Type R Transmission (has 300 miles)
    Stage III Gator Racing Axles
    Custom EGR Kit.
    TURBO KIT: 600 HP Custom Kit
    Turbonetics, Stage 5, 62-1 Turbo, NO shaft play (1600 miles on entire kit)
    4” Inlet!!!!
    Stafford Fabrication Custom Manifold (no bracing required)
    #3 runner tapped and fitted with EGT Sensor, car comes with EGT Guage
    Custom 3”>2.5” Downpipe with 02 bung
    Turbonetics Evolution Wastegate With shims and all springs (dumped to Atmosphere)
    HKS SSK SuperSequential Blowoff valve (has Purple Valve insert)
    Greddy Trust Type 31 Intercooler,Inlet,Outlet Modified to
    2.5" Exhaust back to MagnaFlow Muffler
    AEM ECU wired to AEM WideBand O2 Controller, allows on the fly tuning
    GM 3 Bar Map Sensor
    New Brakes all around with Braided Steel Lines
    Fluidyne 1/2 Bay Racing Radiator
    Car comes with:
    Boost/Vacuum, o2, Tach and EGT Guages
    Also full sound System,
    clarion brb-5475
    Kenwood 6" coaxial speakers x4
    MTX 12" Subs x2 in box in trunk
    600 Watt dedicated Sub Amp.
    MANY,MANY Extras and Spare
    Parts
    Asking $12,500 OBO
    No LowBallers, Serious offers only
    http://http://i170.photobucket.com/albums/u276/Johnnylawless_photo/Car%20Sale%20Files/DSC01634.jpg
    http://i170.photobucket.com/albums/u276/Johnnylawless_photo/Car Sale Files/CAR001.jpg
  2. Johnnylawless
    bump
  3. Johnnylawless
  4. Johnnylawless
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    You still out here in Lancaster? You got that Green EG right?
  6. eg6sir
    cut down your sig please.. its very confusing when trying to read your post
  7. Johnnylawless
  8. Johnnylawless
  9. B16RacerN2NR
    Moving back West...
    :D
    I can vouche for this guy. He used to come in to the autozone I worked at... Quality build :thumbsup:
  10. Johnnylawless
    Thanks for the kind words,
    B16
  11. Johnnylawless
  12. Johnnylawless
  13. B16RacerN2NR
    Moving back West...
    Put this on av-imports.com. you might get a local to swoop it up from you...
  14. Johnnylawless
  15. Johnnylawless
  16. Johnnylawless
  17. B16RacerN2NR
    Moving back West...
    Just give it to me... I'll put it to good use :D :D
  18. Johnnylawless
    cant afford too,LOL my wife would kill me!!!!!!!!!
  19. Johnnylawless
  20. Johnnylawless
    still needs a new home
