So I broke a cam holder bolt. Need Advice ASAP
Discussion in 'General Tech and Maintenance' started by SlushboxTeggy, Sep 29, 2008.
  1. SlushboxTeggy
    New Jersey
    Actually 2. Got a new torque wrench and didn't read the directions for use first. I got the broken pieces out but now what? Can I only get new bolts from Honda? Advanced, Pep Boys, and Lowes(yea I was taking a shot in the dark) had nothing even close.
    I see my 2 options as 1. Get them straight from Honda, or 2. Hit up Craig's-list for a head and just use it for the parts I need.
    Am I missing any options?
  2. efhondakid
    Akron-Canton, Ohio
    Cam holder bolt? Pic please, Im not to sure what your talking about.
  3. SlushboxTeggy
    New Jersey
    The bolts that hold the cam holder plates in place.
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    the things that hold the cams down..theres like 6-8 of them for each cam..
    id say just go to honda
  5. Civichatch9one
    Civichatch9one New Member
    id go honda... thats what i did when i snapped my waterpump bolt because i put the long bolt in the short bolt spot.:(
    but i go majestichonda.com havent had a problem with them yet.
    cant be more than 2 bucks anyway from the dealer (if they have em in stock)
  6. SlushboxTeggy
    New Jersey
    Am I going to pay an arm and a leg or will I be able to get extras just in case for less than a million dollars? I realize Honda overcharges, but their just bolts. Anyone know?
  7. TurboMirage
    should be less than 5 bucks each.
  8. ccsgsr1
    ccsgsr1 Banned
    POCONOS
  9. ccsgsr1
    ccsgsr1 Banned
    POCONOS
    I really dont think honda is over priced. Audi, Mercedes, Bmw ,Jagaur. Those are over priced.
  10. 97hatch
    97hatch ?
    Anderson IN
    Buy the bolt education is expensive these days. You have now learned a lesson at the cost of 2 bolts. It could be worse you could be buying a M6x1.0 heilcoil set and new bolts along with a new head gasket and a few other things. If it would have striped the headout you would have had to take it off to fix or do it the hill jack way and leave the shavings from drilling in the head.
  11. SlushboxTeggy
    New Jersey
    Well dealers in general, but yea, you make a point.
  12. SlushboxTeggy
    New Jersey
    Cool. I'll probably get a couple of each. Now the real question is are they in stock.
  13. SlushboxTeggy
    New Jersey
    BTW, when they say torque to 7.2 ft/lbs. do they mean close to that or does it have to be exact? The only reason I ask is because I have 2 torque wrenches. A click style that starts at 10 ft/lbs. and a pivot handle type that goes lower but obviously will not be accurate to the tenth.
  14. 97hatch
    97hatch ?
    Anderson IN
    there actually usualy measured in in/lbs and i think its like 86in/LB
  15. whiterabbit06
    Crestview, Fl
    I would go with the one that can get the closest I would not use the 10 ft/lb one. Yea 86.4in/lb
  16. SlushboxTeggy
    New Jersey
    Nope, both are Ft/lbs. I planned on using the pivot handle. Just thought I would ask.
  17. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    ive purchased many bolts from the honda dealer for my swap...had to buy all of these holder bolts actually, and usually they have it next day if not in stock, only a few bucks a piece
  18. Briansol
  19. nootrac22
    exeter pa
  20. HATCHET_HONDA
    hobart, indiana
