Ok... here we go again. I have a 89 CRX HF with a GSR swap. Im swapping to a GSR cluster so i kept the electronic VSS. When i wired up the GSR cluster with a wiring diagram that I found online almost nothing worked. The turn signals were always on but flashed a little brighter when in use. So i wired back up the HF cluster that i had in prior to this, and it worked fine for a little bit and then it stopped. All that worked was the battery light, it came on solid even when the car was off. No turn signals, no high beam, nothing... Anyone have any ideas before i pull all my hair out?
