b18c GSR into my 1989 CRX. dropped it in, broke my TPS... but i have another one. Then i fired it up and it ran well just a little high in the rpm because of the TPS. Then i decided to put it all back together and go for a test drive, but i ran into a small problem. The gear shift rod that connects to the shift linkage is snapped off, just past the hole that connects to the linkage. I found a tutorial on replacing the shift rod here Gear Shift Rod Replacement | Honda Integra DIY the website along with the videos it links to help a lot. The problem is where can i but a shift rod. I called the Acura dealership nearby and they seem to have no clue what i speak of even when i try to explain it.
Thank you in advance.
Tom Pappas
Tom Pappas
