So
Discussion in 'Integra' started by LVTeg, Jun 2, 2009.
  1. LVTeg
    LVTeg New Member
    I have a 1990 integra ls with the head gasket blown, what do you guys think i should do, swap the engine for a gsr or a b16, OR rebuild my LS with crower cams & gears and new pistons and rods
    please guys i need your input, dont want to waste my time puttin in a gsr to still run 14s on the 1/4 mile
  2. 95b16coupe
    95b16coupe New Member
    ct
    b16, then get a turbo later on. or another b18a will be your cheapest option.
  3. LVTeg
    LVTeg New Member
    and where would you recommend i get it from?
  4. 95b16coupe
    ct
    it's personal preference.
    If you can afford it. www.hmotorsonline.com
    if you have time to shop around, I would try to get one from craigslist or a local parts forum.
  5. LVTeg
    LVTeg New Member
    yeah i wanted to do hmo but idk paying 1800+300 shipping+700 to drop with with new mounts, hoses and radiator is going to add up ill try looking around though
  6. 95b16coupe
    ct
    why would you need mounts? it's a straight swap. plus, if the tranny is fine, just get a long block. you already have everything you need.
  7. LVTeg
    LVTeg New Member
    I heard b16 long block with an ls tranny would be way too long between shifts
  8. 95b16coupe
    ct
    it's not that big of a deal. it just depends on how much you want to spend.
  9. efhondakid
    Akron-Canton, Ohio
    How about just replacing the HG?
  10. Korax
    Korax New Member
    Western PA
    The B16/LS tranny isn't horrid, but it would be nicer to have a nice hydro b16 tranny in there.
  11. Magana559
    Magana559 The Warden
    fresno Ca
    yes it is, I have that set up right now.
    top of 1st at 43mph 2nd at 70mph 3rd at 105 and i have never toped out 4th.
    but I get 34mpg with short ram, skunk2 intake manifold, 310 injectors, header, and 2.5" straight pipe.
    I would say a b16 tranny with LS 5th gear would be dead sexy.
    try building a high compression LS or LS V-tec.
    Ebay has some PCT replecas by nippon racing pistons for $160 shipped. They arent made for big power but they will make great power and hold up to abuse.
    they will put you in 11.6:1 compression if i remember correct and they fit on stock LS rods with no problem.
    with a good tune that will get you to 14s with other bolt ons and cams.
  12. newb
    newb phresh VIP
    Backwoods Northwest
    +1
  13. DESPAIN
    flower mound TX
  14. jriley58
    jriley58 New Member
    help
    i have a 94 integra i put a b20b in it, but its redlining at 3500rpms what could it be but sometimes it will work right and redline at 6500 or more cant rember help me please:(
  15. newb
    newb phresh VIP
    Backwoods Northwest
    Start your own thread.
  16. BrutalB83
    Rochester Hills, MI
    My dream setup would be B16 / Type R 1st-3rd, GS-R 4th, and an LS 5th...
  17. newb
    newb phresh VIP
    Backwoods Northwest
    ^ Ive heard of ppl doin that but with GSR 3rd and 4th. They say it has awesome versitility.
  18. efhondakid
    Akron-Canton, Ohio
    Im rockin a B16 with an LS tranny and honestly I dont think its all that bad. :dunno:
  19. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    My J1 is hella short, first gear is uselessly short and 5th is too short for the highway speeds.
  20. 99sidude
    Ohio
    1st and 2nd arn't bad in those. Above that it seems like you have to really wind it out. Come to Columbus and drive my gsr trans equipped car or my type r equipped car, might change your mind. The type r with the short gearing and lsd is the most fun to drive, but it sucks on the highway. I'd say the gsr is the best for DD.
