SoCal FS: k20a2 bottom end, k24a1 head and miscellaneous
dc5 jet
everything must go asap. you can take everything for $400
k20a2 block - #1 & #2 cylinder's ROD bearings are spun. cylinder walls, pistons, rods all in good shape. not parting them out selling as is,$250OBO (note: that bronze color is over the block is copper spray heat sealant NOT RUST)
k24a1 complete head - k24a1 cylinder head, valve springs & retainers, valves, cams, cam gears, cam towers, rocker assembly for 225$ comes with everything you see.
check out this chart.
k20a2 timing chain cover - $30 obo
k20a2 timing chain guides (2) - $30 obo
baffle plate - make offer
02-04 type S rear sway - $30 obo
02-04 type S stock springs - make offer
