SOHC Integra
Discussion in 'HYBRID -> EG-EK / DC' started by PhyRe, Sep 30, 2005.
  1. PhyRe
    PhyRe Senior Member
    ct
    yeah so i remeber awhile ago someone over seas had a 94+ teg with a d series in it does any one know where that was. the reason for asking is because and friend and i were just working on a 94 4dr ls, motor is no good. and he needs a winter beater so he has this shell and he has this motor. so were trying to get it in there thinkin well the b18 would fit the civic so the d16 would fit the teg. well we ran into a few things. like it doesnt really fit we get one mount hooked up and the others are off we get the back one in place and one side one and the other is off. does anyone know where the make these stock or of any where that has done this b4 we have all the mounts for a 94 ls AT and for the d16 but its MT. so we think that may be a prob too.
  2. brian11to1
    brian11to1 Senior Member
    Japan, base models.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    You can look in our reference section and see which OEM mounts you need to run the B in a 5G Civic chassis- then reverse the parts (Integra <-> Civic) to get the proper mounts to put the D into the Integra. The only problem with putting the D into the automatic Integra will be the transmission mount- they're different between manual and automatic. You'll have to fab something up.
