Sohc To Dohc
Discussion in 'General Tech and Maintenance' started by frankensteincivic, Feb 11, 2003.
  1. frankensteincivic
    frankensteincivic Junior Member
    i wanted to know if there was anyway if i bought a SOHC vtec d16y8 is there anyway to switch that to a dohc vtec head thanks
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    no, you have to get a new motor.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    No. There are no DOHC VTEC D series heads... and you can't mix/match heads and blocks from different Honda engine series.
  4. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Well, that's not exactly true. PFI up here in Ft. Collins, Colorado (http://www.pfispeed.com) has put an H22 head onto an F23 block, but it isn't easy. You need lots of time, lots of money, lots of beer, and the willingness to go through all the headaches associated with the swap. For the most part, it's always more cost-effective just to transplant a DOHC engine.
  5. phunky.buddha
    Whoops... forgot about the F/H series crossover, as well as the F20C and K blocks... the F and H are still in the same family, for the most part- so it's not too bad. You can share transmissions, right?
  6. dohcvtec_accord
    The left lane
    Yeah, not too bad, but still not something that the everyday garage mechanic would want to undertake.
    I'm under the impression that the trannies can be swapped with little or no problems. I know for a fact that clutch and flywheels are direct replacements. kaoskustoms lives here in Longmont with me, and he said he had a slight problem with swapping an F-series auto tranny onto an H23 block. Chad, can you shed some light on what happened?
