SOHC ZC Clutch
90crxSi/Zc
Im looking to put a ACT stage 2 clutch in my 1990 crx si, I have a single cam Zc in it, When i go to the ACT website it asks me for the cars make, model, year and engine. Does anyone know what i would put for that.(and if it helps i have the stock SI tranny in it)
THANKS!!!
i have a single cam zc vtec in my delsol wiht tha zc tranny.
and i had a racing clutch from my d15 that fit it.
then i got a stage 1 exeddy clutch and i told them it was a d15 and it fit.
so im assuming u can use the d15 d16 clutch in it well at least thats what i did
if its tha stock tranny then jsut enter tha stock motor but when you have tha tranny off make sure tha clutch will fit tha tranny shaft before you put it on.
Year matters, not motor. Are you using the 90 Si flywheel? If so, then you need the 90-91 kit.
89-91 are 20 spline but the 89 has a smaller disc(wouldn't matter if you switch to a aftermarket flywheel; as most, if not all, are 90-91+ spec). the 88 has a 21 spline shaft so would use a different disc than all of them, and IIRC uses a slightly smaller disc than the 89 also.
