Sohc Zc Distributer
I just finished swaping a SOHC Zc into my 89 crx si I used the distributer from the ZC motor and wires. when I turn the key it cranks but theirs is no igntion sparking is it because of the jdm distributer?
I was thinking is it's not sparking because of my ECU since it's a 89 crx si ECU not compatable with a jdm distributer I'm gonna go ahead and buy a 89 integra ECU and see if that works.
Anybody have any other suggestions please let me know thanks :)
NO the Si ECU should start and run it. When you say you used the ZC dizzy and wires what exactly do you mean? Did you have to change any plugs or cut and solder any wires? How do you know no spark? Did you pull the plugs and ground them and check?
Make sure your plug wires are plugged in the right order. Sounds simple, but you might be surprised. Otherwise, all I can say is I'm using the same distributor from my D16A6 on my SOHC ZC, so I can't be of much help to you there.
