Originally posted by Calesta@Mar 20 2005, 05:07 PM
If you're talking about the SOHC ZC non-VTEC, all the parts are pretty much the same as the D16A6 (88-91 Si) except the camshaft. Just use an 88-91 CRX Si valve cover gasket.
[post=476145]Quoted post[/post]
Originally posted by reckedracing@Mar 20 2005, 05:23 PM
you = retard
you must be a member of that site to view pics...
[post=476158]Quoted post[/post]
you = retard
Originally posted by reckedracing@Mar 20 2005, 05:32 PM
alright, you need to look by your distributor...
the vtec solonoid will be there...
google it up to see what it looks like...
do you know what the block is stamped?
i would suggest you get the D16A6 valve cover, that should work for you..
its from a 88-91 civic SI
[post=476163]Quoted post[/post]
Use from this location denied. Referrer is HTTP://WWW.HONDASWAP.COM/FORUMS/INDEX.PHP?...13&T=53478&ST=0
[post=476168]Quoted post[/post]
