Currently I have a Sohc Zc (The non-vtec version.) Yes, there is a vtec version available, look it up.
The problem I have is that I think I messed up my valves a bit doing the timing WRONG and now they are clicking. So, I am looking into which VTEC head to put on my car. I have a few choices. The D15 vtec head or a D16 vtec head, but which is better, which is easier, and which is cheaper. That, I have no idea about.
If you don't know anything about this type of thing, please don't say anything useless.
I'm only concerned about a few things.
- I don't know how to do the wiring for the Vtec.
- I want to use a smaller head gasket for a little more compression, but I'm not sure which type to buy.
- If I do lower the head a little tiny bit closer, are my pistons (Which I know nothing about the pistons in that particular motor.) going to be contacting the valves of a Vtec head?
Keep in mind, the Sohc Zc is almost identical to the D16.
I'm not sure of the differences between a sohc zc non-vtec and a d16a6 that is normally in an 89 crx si.
Any help at all on this topic, as soon as humanly possible would be great. I need to do this quick so I can start driving again.
Here's what's done on the car now so you can all get to know the new guy.
It's pretty comprehensive.
1989 CRX Si
SOHC ZC
Si tranny
XTD Stage 3 clutch
XTD 8 lb. flywheel
3A Racing Short shifter
Greddy Shift knob
Ractive Header
High-flow cat
Bosal 2.5” Cat-back exhaust
AEM Cold air intake
K&N Air filter
AEM Underdrive pulley
Unorthodox Ultra R Crank pulley
Prelude brake master cylinder
Integra Rear disc-brake conversion
Brembo Slotted/Drilled front rotors
Stainless steel braided brake lines
Front/Rear strut bars
Suspension Techniques lowering springs
Tokico gas shocks
Suspension Techniques Front/Rear sway bars
Neuspeed rear lower tie bar
Front lower tie bar
17”x7” aluminum alloy rims
Wanli S1088 205/40ZR/17 tires
Grant GT steering wheel
Shift light 7k RPM’s
Projector headlights
Clear corner lights
Clear bumper lights
170w headlight bulbs
LED corner/turn signal bulbs
Optima Red Top battery (Behind passenger seat)
55 watt Fog lights
Weight reduction
1989 CRX Si
SOHC ZC
Si tranny
XTD Stage 3 clutch
XTD 8 lb. flywheel
Greddy Shift knob
Ractive Header
High-flow cat
AEM Cold air intake
K&N Air filter
Tokico gas shocks
Front lower tie bar
Clear corner lights
Clear bumper lights
55 watt Fog lights
Weight reduction
