solenoid valves
oldschoolcivic
Ok i have a 90 civic lx and putting in jdm b16. I see the jdm is suposed to have purge cutoff solenoid valve and a pressure regulator cut off solenoid valve. My car has the purge cut off solenoid valve. So my question is what am i suposed to do with the wiring, or do i need that pressure cut-off valve.
you don't actually need either one for the car to run just fine - connector for purge solenoid should be on your harness, if you choose to hook it up
