Solo II classifications
Discussion in 'Members' Lounge' started by CRX-YEM, Oct 28, 2003.
  1. CRX-YEM
    Wallingford, CT
    does anyone have a link to a descnet list of classifications ??
  2. 94RedSiGal
    94RedSiGal Senior Member
    Massachusetts
    Oh. I finally figured out that descnet=decent! Here you go...
    SCCA Solo II Car Classifications
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    for CRX's, if they are even slightly modded, your going to be in CSP which means a super high class. CRX's own in stock class.
  4. CRX-YEM
    Wallingford, CT
    by the looks of it buy the rules listed from that link I'll be in HM (H modified)
    or possibly HSP (H Street Prepaired)
  5. asmallsol
    I dont think i have ever heard of an H mod car and there is no thing as HSP, FSP i think is the lowest street preparded class. What mods do you have?
    If you think that your car is in a street preparded class, use this list.
    http://www.moutons.org/sccasolo/Lists/2003...03/stprepm.html
    Stock class and street preparded class has little relation to each other.
  6. SixtySecondAssassin
    Austin, TX
    so what happens when you've swapped motors?
  7. asmallsol
    It depends on what car you have and what motor you put in there. If you have a 98+civic coupe, then you can put a USDM b16a2 in there and run in stock class (what ever the stock SI is in) or STS. If you throw an engine that was never offered in that line (like a gsr in a sol) then you are in Street Mod or street Mod 2 (del sols and CRX's with swaps go to street mod2) If you have any internal work or if you have a turbo, you are automaticly bumped up to SM.
    BTW, 2 seaters like the sol and the CRX can not be in STS, STX, or Sm. For the sol, only SM2 and DSP.
  8. GSRCRXsi
    MD
    so what class would my GSR powered CRX be put in?(its all motor) and when they talk about modified are they only referring to engine modifications? or do suspension modifications determine your class too?
  9. asmallsol
    any CRX with a b series is in street Mod2
    Yes suspension heavly effects your class. A dead stock hf CRX with springs would be bumped up to CSP vs h-stock. To give you a little perspective, CSP is the same class as the ITR (remeber with a decent amount of mods, most ITRs go into STX) miatas (the ulitmate autoX car next to the RX7), and the e30 M3's.
    The most comeditive a honda can be is in stock form with koni shocks (shocks are legal in stock class not springs), stock diameter wheel by 7 inches (it may be 8 as the limit) with r compound tires street slicks (DOT rated) If i were to build an autoX car, it would be a first gen CRX with the above mods.
  10. CRX-YEM
    Wallingford, CT
    Car Specs
    91 CRX DX
    Stock 1.5ltr motor
    Exhaust
    CAI (AEM style)
    KYB AGX w/ Neuspped Sprt Springs
    15 x 6.5" Rota's with Kumho 712's
    other than that a stock CRX.
    so help me classify my car for solo II , I'm just trying to see what other types of vehicles are in my class for next year. thanks
  11. asmallsol
    ha that sucks for you, CSP. Have fun.
    The wheels (bigger then stock) bump u,
    CAI (counts as a motor mod) bumps you
    springs bump you.
    Since you have a 2seater plus a CRX, any mods and there goes your chance to be compeditive
    Exhaust is legal in all classes (just not the header)
    EDIT this deserves more respect then anything goes, someone move to the racing forum :moved:
  12. GSRCRXsi
    MD
    so i would be in mod2? what kinda cars does that make me competing with? look in my sig for all my performance mods, am i still in mod2?
  13. 94RedSiGal
    Massachusetts
    I was thinking the same earlier, but then I would have missed his post. This question would have been okay in the NE regional forum too, as we all go to the same events. :shrug:
  14. pissedoffsol
    H-stock exists :) I ran the 240 in the last weekend.
  15. asmallsol
    H-stock exists (most stock civics are in this class except for VTEC sols, EK SI's, integra's (not sure if the LS is G stock or H stock) but there is no H mod or HSP.
    Your car would be in STEET mod 2. In street mod 2, your going up against turbo miatas, sol's with swaps, Moded Vettes, Porsches. Unless your mario andretti, you dont have much chance. Just go and have fun. I doesn't really matter if you win or lose, its all about haveing fun.
  16. CRX-YEM
    Wallingford, CT
    that's all I want to do is have fun, and my only competitor is myself.
    was just trying to figure out what class I'd end up in.
    anyone know what class clayton is in with his rex ??
  17. 94RedSiGal
    Massachusetts
