Some Belt Problems
1995EGGuy
I swapped a b16A SIR-II into my 95 civic but when i bought 3 new drive belts for a 95 honda del sol dohc vtec, i could only use one of them and i had to use two of the old ones that came with the engine. But the two used ones are about to go, so from what car am i able to get these new belts from?
do you have a del sol a/c bracket and using the b-series a/c compressor?
or, did you run the d-series compressor?
powersteering should fit-- loosen the wingnut down, and the 2 bolts on the side to slide the tensioner.
b16a2???????? or b16a3????????
get that one for the motor that it is if it for a b16a2 99-00 civic si
if its b16a3 94-97 del sol vtek
hope this helps man
ya boy steveo
