Ok im new here so i hope u guys can help me. I have a 98 civic that had the d16y8 in it w/ the p2p ecu. Im swappin in the jdm b18c using the obdii p72 ecu. Ive made my wiring mods(lengthened some harnesses and changed connectors) and ive put the vtec pressure switch in. The car starts but doesnt idle for sh*t. So i went through some basics.. it has spark, fuel, cam timing is right and it has hella compression.. like holding around 240(thats realy high for some reason). Anyway i need some help any suggestions on where to start. Motor came from hmotors so im sure its legit. I would like to find a pinout for the obdii p72 besides whats on hyrbid garage. any help would be good. not sure if i should still b checkin my wiring or if i should start lookin mechanical.
Thanks in advance.
Thanks in advance.
