Somebody Help Me...My computer wont Start.
Discussion in 'Computers, Games, Electronics etc' started by hondamidnighter, Jan 21, 2005.
  1. hondamidnighter
    hondamidnighter Senior Member
    Ive been having a problem with my laptop that it wont charge or turn on...could it be becuase the battery is dead or expired. Or could it be the adapter? Somebody help me please it is a Hp. I update the series if i find it.
  2. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    It's probably the battery.
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    most likely the battery, check your voltage from the adapter, it should be sending power... most likely the battery is cooked
    check www.pricewatch.com for a new battery
    or maybe its still warrantied?
  4. cxjon
    cxjon Senior Member
    man+k+toe
    hmmmm maybe itd because its a HP
  5. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    I agree but it is a HP so it could be anything. I use a HP at work just for email though and sometimes it needs a good kick to get it working. :bash: = That is what I want to do to it. On another note we are throwing some Dell laptops off the roof today. :lol: Fuck Dell.
  6. Bob Vila
    Bob Vila ɐןıʌ qoq Admin VIP
    Bristol, Ct.
    Get some jumper cables if it won't start :)
  7. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    I disagree with all of you guys. If its a bad battery, it will still turn on with the AC plugged in. If its a bad AC power brick, it will stop charging, and the battery will eventually die and no source of power will be present.
  8. reckedracing
    NY
    some laptops need to have the battery operational whether its plugged in or not...
  9. Havok
    Havok Senior Member
    Florida
    Did you try pressing the power button?
  10. 94CivicSlow
    B0ST0N
    Not hp's.. and he said he has an HP.
  11. hondamidnighter
    Well the battery has gotten some charge but the charge light doesnt stay on. In other words the battery gets charge while the light stays on then turns off then turns on back again. And when the light stays on I start the computer then the light turns off completely. But I guess ill go buy a battery and try if thats the problem.... :angry:
    sorry guys for not responding for yall suggestions. :)
  12. Sabz5150
    Sabz5150 FALCON PUNCH!!!
    Some laptops will not work at all with a cooked battery. My friend's old Dell would do that.
    Take the battery out and try starting it up.
  13. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Same thing happened to mine, I guess it was the motherboard.
