Somebody Please Help Me!!!!
Riceras
My motor is a D-15????? Is that normal for that year because I have a Hydro Transmission??? Also Can someone please Post everything I need for and OBDII B-16A2(SiR) Swap??? I am running into problems everyone tells me different Things Please Post the things that I should buy to complete the swap!!!!
Originally posted by 92civicb18b1@Dec 27 2004, 06:01 PM
theres an article that describes everything. What car do you have also?
[post=437771]Quoted post[/post]​
the title says 97 cx....so probably the hatchback?
if you have obd2a civic you are good all you need to do get a converter for an obd2b for the ecu or you need to get an obd1 converter for you to use an obd1 ecu but as far as the engine goes if you get the complete b16a2 from a 99 civic then you are good just get the wiring diagram for your car and go from there i put a b16a2 (obd1) engine in my 97 civic and i got it running great just got the get the altenator working!
https://hondaswap.com/forums/index.php?showtopic=41608 for the vtec wiring if you need any other answer just ask away
