Someone help
Discussion in 'Civic and CRX - EF' started by riftonthemind057, Jun 2, 2008.
  1. riftonthemind057
    riftonthemind057 New Member
    I have a d15b2 that I just put a clutchmasters lightweight flywheel and stage 1 clutch in. Everything went well until after the install. I'm now getting a code 1 and my battery light comes on around 2,000 or so. if anyone could help it would be very appreciated.
  2. BrutalB83
    Rochester Hills, MI
    Um...yeah...I'm not sure if your clutch really has anything to do with any of this. Code # 1 should be your primary oxygen sensor, so check up on that. As for the battery light, I dunno, get your battery checked? The only thing I can think of is that you knocked something loose or forgot to plug something back in when the clutch job was done...
  3. riftonthemind057
    I didn't really think the clutch didn't either but maybe the timing somehow moved. When the transmission went back in we broke the wire behind the connector to the o2 sensor we rewired it. How do I check resistence on the o2 sensor? The battery light coming on is the most confusing part to me.
