So the current status on my B16A1 '89 CRX is this. If the VTEC is working, I don't notice it, which seems unlikely, so I'm guessin its not workin. Secondly my rex starts to smoke it hard when I'm driving, and rev past 5,500 RPMs, then after about 5 minutes will stop, but it still smells like a go-kart. These are the following codes that my ECU is throwing at me.
According to http://www.integra.orcon.net.nz/ecucodes these are what the numbers mean.
"2) Oxygen sensor "B" - Defective circiut or unplugged/ Defective sensor"
"10) IAT (Intake Air Temperature)sensor- Defective circuit or unplugged/Defective sensor"
"14) IAC (Intake Air Control) Valve- Defective circuit or unplugged / Defective sensor"
"23) Knock Sensor - Defective circuit or unplugged / Defective sensor"
I ran a search and someone said that VTEC sometimes won't work if your knock sensor is not working properly. Could any of these cause me to burn my oil so badly? Could this be the reason why my VTEC does not seem to work? Can I check any of these sensors myself?
Thanks a lot,
Scott
Thanks a lot,
Scott
