Stleger184634
Ok so from my previous thread I swapped in a F20B into my 98 prelude and I was not getting power to my fuel pump and past my Main Relay, and when I turned the key the main relay would pop click and try to blow up . Since then I have Installed a BRAND NEW Main Relay ( fuel pump now works), did OBD1 conversion w/ chipped p13 ecu w/ stock f20b maps, gone back over all the wires and checked the grounds.
and...
I still have no spark =(
I hooked back up the OBD2 ecu used a scanner nothing flashed but the code "P1259" or the vtec pressure switch which the F20B dosnt require hooked up so i jumped the sensor and the check engine light went off. So i hooked back up the OBD1 ecu, checked my coil, and all sensors related to having spark everything tested fine. I am at a total stand still on this swap. Does anyone have any suggestions? I am open to all suggestions at this point I will try anything unless it dosnt pretain to my problem.
Thank you guys very much =)
and...
