Sorre got a newbie question...
Discussion in 'General Tech and Maintenance' started by lhracer05, Nov 11, 2002.
  1. lhracer05
    lhracer05 Junior Member
    Hey everybody....i know this is dumb.....but itd realle help me if u guys can tell me what raises rpm on an engine.........thanks a lot
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    The gas pedal. Or do you mean the rev limit?
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    as more air/fuel ratio goes into the engine (when you press the gas and the throttle blade opens) It makes the engine have more fuel mix which in turns makes the pistons move up and down faster and faster. Check out places like howthingswork.com (i think that is the right address). Oh and welcome to honda swap. Stick around and you will learn a shit load
  4. 92civicvx
    92civicvx Member
    the gas pedel thats the best thing that i have heard all day :lol:
  5. zueke
    zueke Senior Member
    Lansing, MI, USA, Earth...
    asmallsol: The website you are looking for is Howstuffworks.com
    Just thought I could be a help.
  6. asmallsol
    that is what i ment
  7. lhracer05
    thanks u guys.....but i was kinda meaning like what parts make the rpm limit go higher......sorre.....
  8. SnailOnARampage
    SnailOnARampage Senior Member
    Utah
    The ECU (car's computer) is what controls the rev limiter. If you rechip your ecu you can (but its not recommended) get it to rev higher. If you rev much past the red line on a stock engine, it is likely that you will get "valve float", and this can cause a valve to smash into a piston. Also, without different cams, you will lose power really really fast when you go past the red line.
    so basically if you want to rev higher, you will need:
    A rechipped ECU
    New cams
    New valve springs, retainers, and possibly new valves.
  9. SnailOnARampage
    Utah
    just a note...the reason why a f20c head (s2000) does not get valve float past 7200 rpms, is because the valve springs are a lot stiffer than the civic's, so they are able to open/close faster. Just another note, with stiffer valve springs, you are making the valve hit harder each time it closes, so stiffer valve springs can also cause valves to wear prematurely...thats why its a good idea to upgrade those too.
  10. bte15
    bte15 Senior Member
    Bellevue, Washington
    thanks snail didn't know that
  11. SnailOnARampage
    Utah
  12. lhracer05
    Thanks a lot snail.........hehe...snail?....well ne ways, ure my hero
  13. pissedoffsol
