Spark Plug Gapping?
Discussion in 'General Tech and Maintenance' started by lude68, Jan 5, 2004.
  1. lude68
    lude68 Senior Member
    Bought some new spark plugs today and was wondering what size i need to gap them at (my car's in sig)? Thanks!
  2. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Did you install the engine yourself? If so, just refer to the manual for that motor. If you didn't install it yourself, ask the guys that did, and test their customer service. :D
  3. Airjockie
    Airjockie Watanabe Whore!!!
    Meriden, CT, USA
    if your boosting..you will need to set the gap smaller.....
    I've heard that a 0.020 gap is fine for boost, I've tryed it and it worked wonders...the reason they say to keep the gap that small it to help keep the spark from blowing out....when you really need it. Unless you have an MSD system, then the gap should be small.
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    if it's NGK's then it's already gapped from the factory.
