spark plug
Discussion in 'RSX' started by carlitoswaypr, May 31, 2008.
  1. carlitoswaypr
    carlitoswaypr New Member
    BRIDGEPORT CT/ PUERTO RICAN
    i need to do a tune up so wich spark plug are the best for my RSX TYPES.. dont care about $$$ i want some power because the torque is low...
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    ngk
  3. carlitoswaypr
  4. AHHVTEC
    Alabama
    yea the best you can get, id actually just go to the dealer and get them
  5. BrutalB83
    Rochester Hills, MI
    I think that's more a symptom of owning a Honda then bad spark plugs... :D
    If the plugs truly are worn out, you might see a little bump in power (it's restored power, you're not really gaining anything), but I wouldn't expect much...
  6. teggyguy
    teggyguy high density foot.
    Colorado
    plugs and wires will make the power more smooth (and may actually revamp it to what it was) piece of advice order some 10mm core offa ebay get some ngk iridiums(sp).
    For power.... you're ricer i take it there is an intake....so clean your air filter, get a header back exhaust with an expirimental cat (hehehehe wont pass emissions i don't think)
    but some performance stuff.
    I think it was brutal that actually stated TORQUE on FWD cars = bad
    HP = good.
    Try to balance it with about 30 to 40 less torque than hp, and find the % weight in front of the car and set the torque up to pull that but no more than you need cause you're just goin to spin your wheels and not go anywhere.
    TORQUE is the shizz for old gas guzzlers.
  7. BrutalB83
    Rochester Hills, MI
    I was just saying that Hondas are torque-less little things. Torque is good if your car is properly set up for it (i.e. good suspension, good tires, LSD, possibly some traction bars, etc.). This is the inherent weakness of trying to build a fast front-drive car though, traction will always be a problem...
  8. carlitoswaypr
    my cousen bought a civic si 2007 and i drove it and its way faster than my rsx . every tells me that its no a big difrens but i felt more power than mine.. i got mine for 6 month and i know my shit its slow... tomorow im going to put headers no cat.. to see if it still slow if it still slow .. i will buy a sing FOR SALE... :( my rsx has 124 mile its a 2002 and the last owner use to let his wife drive it so i might buy a brand new clutch... which one should i get ?? wich one is cheap and good ?? and wich one is the best (no matter what price is it ?)
  9. eg6sir
    ahhh.. .. headache
  10. AHHVTEC
    Alabama
    its a drivers race between those cars make sure its a race header and it will open it up a lot.
  11. BrutalB83
    Rochester Hills, MI
    :werd:
    Give yours a nice intake, a decent quality race header, a nice exhaust, and a tune-up and you should feel a nice difference...
  12. carlitoswaypr
    i got AEM intake, 2" cat back , and exhaust.headers .. but its slow real slow.. feels real heavy.. i friend told me is the cluch .. because the rpms dont move fast enogh.. let say it like this in 1st gear the car sound real loud and you think theres a fast car coming but going slow and the rpms has not even touch 8000 rmp.. and cant do realy good burn out like my old 95 integra LS
  13. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I'm surprised no one caught this; but the RSX doesn't use spark plug wires.
  14. coco_nut909
    coco_nut909 Joker
    Ontario
    ngk platinum iridium laser welded plugs their racing plugs costs about hundred bucks from kragens and are worth ever penny and if you dont believe me go find out for yourself
  15. BrutalB83
    Rochester Hills, MI
    :werd:
    How do you know that's not a placebo effect? Did you actually dyno your car stock versus just with the new plugs?
  16. coco_nut909
    coco_nut909 Joker
    Ontario
    yes the automotive program at Fullerton CC has a dyno
  17. BrutalB83
    Rochester Hills, MI
    Then how much power did the plugs add?
