spark plugs for boosted apps?
Discussion in 'Forced Induction' started by knuteiriktveiten, Dec 12, 2007.
  1. knuteiriktveiten
    knuteiriktveiten New Member
    Louisiana
    hello, I was wondering if anyone knew the best sparkplugs to use with a boosted gsr?
  2. new2me93
    new2me93 New Member
    I know that some plugs take up more room in the combustion chamber giving you slighty higher compression. The ones i know that do this are Bosch Platnum +4's and the NGK's.
    I am using NGK's in my N/A b16 and on the dyno they acually gave me 1 more whp because of the compression increase! So I would stay away from these with a turbo.
  3. formby
    formby learning in progress
  4. danse
    danse Junior Member
    I only run NGK, for me they work I'm sure there are other choices but they are cheap and they work well. If you are not running a hot coil gap at 28 thousands.
