definately speedo cable, two hoses are pinched off, motor from hmo. 90-93 xsi b16a. cable trans.
hey this motor also came with something missing on the back of the throttlebody, is that the throttle position sensor? round hole with a gasket.
Yeah, I'm wondering the same thing. Speedo connector on the b16a gen1 has two ports for fluid?
So, you just take the speedo connector from the old d16 engine and use it with the b16a gen1 engine?
Ok, so I put the speedo mount from my d16a6 onto the b16a and it seems like it should work. The only thing I'm concerned about is that the gear is higher in the transmission due to it being higher on the shaft, but not by much. Has anyone done that switch? And did it work?
